Asunto: Improving Some Parts Of Xciting 500(5/11 Update)
Here are some parts that I have modified and I would like to share with you.
The module of handle(12V socket, voltage regulator and filter,valtameter)
The new type dual lampshade and Ninja 250 mirror
front open mirror
front close mirror
side open mirror
side close mirror
That have good externals, but the view becomes bad than original mirror.
The net of radiator
The dual 4 piston caliper and stainless footrest
The giant DOHC 4V cylinder header
To augment the ignition
NGK blue ignition wire and Denso iridium spark
To augment the ground wire(99.997% copper cable)
Leo Vince tailpipe、thermal insulation、RPM G Plus dual shock absorber 、rear mudguard of Downtown 300 、GTS24
Looks like a racing scooter
SIMOTA air filter extra work
To use cleaner and oil every 800km.
front
back
Another air filter extra work
The black lampshade
Others
The stuff and tools to modify Ninja 250 mirror
CVK36.5 burnish extra work
My 150cc scooter → SYM Attila 4V (I have ridden for ten years)
Both of my bike
take a photo
YA!
~Thanks for your attention~
Best Regards,
Última edición por Spook el 11 Mayo 2010 13:29; editado 2 veces
Asunto: Re: Improving Some Parts Of Xciting 500
AMAZING WORK!!! :shock:
Best Regards from Spain ;-)
Hi Spook,
i'm really amazed on your work. Where do you buy all those accesories? Some webpage? Or do you make them by your own?
See yaa..
impresionante, estoy alucinando, cuantas cosas a la vez, estoy por meter la cabeza bajo tierra como jarjar... :shock: :shock:
Y si entendiera lo que pone... :difus_14 :difus_14 :difus_14
Los chinorris estos nos van a comer
Hi, my frinds
Here are some problems confused me, and i need your help !
Because the engine type of my Xciting is carburetor ( ignition by CDI ) not throttle ( ignition by ECU ).
I am aware of the CDI have rpm limit.
As I have known:
1. Bike: Xciting 500
2. Bike made date:2006.4
3. engine model : SAA0AA
4. engine type : carburetor
5. ignition system : CDI
6. CDI made date : 2006.3
7. rpm limit:9100 rpm
2. Bike made date:2006.11
6. CDI made date : 2006.10
7. rpm limit:8200 rpm
1. Bike: --
2. Bike made date:--
3. engine model : --
4. engine type : --
5. ignition system : --
6. CDI made date : --
7. rpm limit:--
Could you kindly provid the information like above ?
I need to know that the relation between "CDI made date" and "rpm limit",
especially the CDI made date in 2006.6~7.
Please do me a favor~
Thanks for your great help!
Best Regards.
where i can read the rpm limit?
There are some pics about my CDI:
http://www.xcitingclub.es/viewtopic.php?t=905&highlight=cdi
About motorbike build date, i think that we don't know that data, because we only know incoming/import date.
kUcHilla Escribió: [Ver Mensaje]
Hello kUcHilla,
I would like to know why you buy a new CDI ?
The old CDI broken ? or other reason ?
Thanks for your photo about the bag of CDI, that helps me a lot!
I guess that i have found the rule of CDI version
(the version 3 seems have 9100rpm limit ; and the version 4 seems have 8200rpm limit).
And I need your help to double confirm that, please kindly do me a favor.
In order to know the rpm limit, you must testing as below:
After the engine of Xciting warm, you must to prop up the middle stand and turn the grip full down,
likes you test the air filter.
Link
Then you will see the rpm limit on your tachometer, and you can loose the grip after you saw the rpm limit.
Please tell me the result after you test.
Best Regards.
When i bought the motorbike, the laws of my country didn't allow me to drive it because i only had got one year old my "driver card". Then i bougth the motorbike and CDI limited to 34CV. Nowadays i be able to drive without limitation.
About the test of rpm, i'm sorry, i can't test it because my motorbike is being fixed on the repair shop due to traffic accident :(
However, driving the bike before i saw the rpm limit on 8200, because i wear a leo vince 4 road.
See you.
See you.
Thank you, my friend
I hope your Xciting can repair as soon as possible.
Then you can ride it to many place that you want to be.
Best Regards.
Hello, my friend
I have saw some information about 34CV in your country.
It's a very special rule and i never hear before.
http://www.anesdor.com/pdf/CatalogoLimitaciona34CV_Rev0.pdf
It seems used 33mm pipe limitation on Xciting 500R,
but how about the 34CV limiter on your Xciting 500 ?
Using 33mm pipe and CDI limiter ? Or one of these?
Best Regards.
Página Generada en: 2.0782s (PHP: 25% SQL: 75%)
